WD Engine Question
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: WD Engine Question
    Posted: 21 Jan 2010 at 8:05pm
What's the purpose of the plate on the right side of the upper part of the engine block?  (I'm talking about the one that was eliminated on 45's) What does a person see if the plate is removed?  Why would the plate ever be removed?  Thanks for the education............O_O
Why is there never time to do it right the first time, but always time to go back and fix it?
NCWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCWC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 8:23pm
I beleive that the tops of the lifters and the pushrods would be showing if you removed that plate.
B,C,CA,RC,WC,Unstyled WC,WD,WD-45,B puller, WC Puller,WD Puller, WD-45 Puller
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2010 at 10:02pm
Yep.
alliswd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alliswd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 12:22pm
My belief is that - at the time - the casting capability of the thin core required between the cylinders and the "plate" was not able to withstand the pour.  So they tied the core into the sand outside the block thru the big hole that the plate covers up, so that it got the support it needed.  When the technology improved ( probably better binders in the sand ), they where able to remove the plate and cast the outer wall inplace.  Just my hypothesis...
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 12:59pm
There is no "hole" that the plate covers up, all you can see is the pushrods.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 1:05pm
Jordan, I believe Dean is talking about the large cavity that push rods go through. The same cavity that the plate covers.
