Wd engine kit
Onalaska Ben View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Onalaska Ben Quote  Post ReplyReply Direct Link To This Post Topic: Wd engine kit
    Posted: 04 Nov 2019 at 12:54pm
Looking to by a rebuild kit for a 51 ed. Is there a difference in which brand I get. I've searched this site for help but haven't seen anything besides used parts being talked about. In my area there aren't many ac tractors so I thought I'd save this one from the scrapper. Guys around here haven't been much help for ac tractors. Green and red are not a problem but mention an orange tractor and all the know of is kubota. Lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 1:40pm
Are you absolutely sure your engine has a WD crankshaft (4 inch stroke) or a WD45 crankshaft (4 1/2" stroke) ??  This makes a difference on which motor kit you buy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 1:41pm
Onalaska Ben,
You could try some of the suppliers listed on this site. I know Tony's Tractors and Sandy Lake can get engine kits for WD's.
Good luck saving another orange tractor!
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 3:58pm
OK Tractor or DJS Tractor Parts.  Like Doc said, make sure you know what crank you've got.  Might want to measure the journals and make sure you can get rod and min bearings before you go too far.  They don't make as many sizes as they used to.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Onalaska Ben Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 4:06pm
It is a 4" stroke 4" bore when I tore it apart. Crank will grind to .010/.010 and has the smaller main.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 5:58pm
Ben,
The kit I got for the 45 was a Riley brand kit. Worked good.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 7:15pm
I got mine from NAPA. Every thing including rods and mains came from them.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2019 at 4:29pm
Lot of good Allis guys on here from the NW, between Darryl and Eldon they probably have all the orange in the state of WA, no wonder there is none around. Tony Carbaugh is down in Oregon and is a vendor on this site (Tony's Tractors) and is who I bought the kit for my WD from. I'd recommend calling him, you will get the exact parts you need and a great conversation to boot.
Edited by Bill_MN - 06 Nov 2019 at 4:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Onalaska Ben Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2019 at 5:02pm
Thanks guys. I'm sure there somewhere out there but don't see them alot. I'm newer to the tractor scene. Been a few years since I've been down to Brooks Oregon for the steam up. That's about the closest to me for a big show. I've always had a warm spot for any old piece of iron.
