WD engine heater
MNfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmer Quote  Post ReplyReply Direct Link To This Post Topic: WD engine heater
    Posted: 08 Jul 2020 at 4:53pm
Is it possible to plumb a tank heater into a WD?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2020 at 5:31pm
In a word, Yes...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2020 at 5:51pm
Where is the correct place to plumb it? I went from the block drain to the water pump and it won't circulate.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2020 at 6:14pm
Been a long time, but if memory serves I went from the block drain to the thermostat housing. Dont remember if there was a plug or I drilled and tapped.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2020 at 7:31pm
 tank installed vertically ?
if it's laying down it probably won't circulate correctly
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2020 at 7:44pm
It's at about a 45 degree angle.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2020 at 7:55pm
Goes from the bottom of the block to the thermostat housing on the near side of the thermostat. I used two short of rubber hose and a small piece of metal to get the block heater completely vertical. Ironic question for a 90 degree day
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2020 at 8:54pm
You are risking burning up the element, that way.  Proper way is to have it  in a vertical line.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2020 at 4:10pm
I always do have them vertical, but mine doesn't have an outlet on the thermostat housing. Thanks everyone for the info!
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2020 at 4:12pm
One of mine has one on it---dont think it works, but its hanging on there.
