WD done, WC not so much
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Topic: WD done, WC not so much
    Posted: 30 Mar 2010 at 5:53am
I got the WD done, other than a few little things.
Not some thing that is original, but I am happy.
On to the WC that came home Sunday, not sure if it will get done or not sure needs a lot.I'm a bit confused (easy to do) with serial #'s tractor WC 170962, engine W28183K.
I think the tractor is 47? engine? 36?  Am I even close???
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 6:07am
Nice looking WD! Did you go through the entire tractor? On your WC, SN is for 1948. Don't know about engine # - others will help.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 6:15am
WD looks good. Is the WC engine number stamped in the center rear of the block were the starter kinda hides it? That would be an early pre starter block. 170962 would be a 1948 tractor. Lots of em had engine swaps over the years, most being swapped out for a later engine instead of an earlier one.
 It shouldn't be much of a problem to make the WC look as good as the WD does. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 6:16am
No, I changed all of the fluids, replaced the block (twice), new radiator, new alternator, new wiring, new tires and tubes, repaired the hydraulic pump, cleaned out drans and diff to get old lub out. New paint and decals.
I am happy with it, was not looking to do a complete restore, just wanted a good looking daily drive.  I am not a farmer, just sometihing to do in retirement.
The WC has the serial number for the engine in the center rear, hidden by the starter, Yes.
Edited by Gary in Texas - 30 Mar 2010 at 6:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 6:20am
Gary, if you get bored, come on up to Massachusetts! I've got several that need going through.
WC, CA, D14, WD45
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 6:25am
That WD sure looks good!
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 9:48am
I like the looks of the bench seat. I am 300 lbs. Two supports under my rear would help alot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 7:42pm
Real Nice looking WD Gary! Came out real nice! Congrat's on a job well done!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 7:48pm
That is one fine looking WD!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 8:46pm
ver nice Gary.. did you do the paint? what brand?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 9:21pm
I did the paint myself, used a Harbor Freight HVLP electric spray system.
Paint is Van Sickel, Persian Orange #1, with hardener, from ATWOODS.
I like the look, but I did have a flaw or 2 in the paint.  But I am happy with it.
