WD diet
dgerth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Topic: WD diet
    Posted: 24 Apr 2019 at 7:08am
Gentlemen,
Need some ideas on how to lighten up the front of a WD. Currently, weigh-in at 3540 and would like to loose about 100#. Is it possible to remove the hand clutch/pulley housing as there is nothing in there anyhow. What say ya'll?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 7:18am
My WD weighs 3100 with 15.5 x 38 tires, wheelie bars, the torque housing and weight racks. Change out your front pedestal to one from a WC and you should lose some weight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2019 at 10:16pm
Thanks Doc.  Would any generic WC FE work or is there a particular Yr or # that would be best.
dg
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2019 at 7:20am
Older is probably better, but I'm sure any WC will probably weigh less than any WD.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2019 at 9:21pm
is a rc narrow front any lighter than a wd front?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2019 at 10:04pm
Probably, because it is either the same as a WC or even lighter yet.
