wd diesel ?
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Topic: wd diesel ?
    Posted: 18 Feb 2012 at 8:25am
what is the difference in a wd wd 45 and diesel rearend or is there any is the tranny different ?   are the diesel rears geared heavyer or lower is ther any advantage to a diesel rear for pulling thanks for the info Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 8:54am
I don't know if there is a difference between the WD and WD45 rear axle gears, the gear ratio for the 45 diesel is higher than the gas version. To get about the same HP from the diesel it had to turn faster. You can also get the ring gear and pinion out of a D17 to turn a few more RPM's in your WD45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 9:08am
Most WD's had spur gear transmissions so the top shaft which has the pinion gear for the differential is probably different. WD's with a curved shifter would have the same internals as a 45.
 I wonder about the output shafts with final drive pinions, if they were different in the WD and 45. Also if there is a difference, what ratio is the final drive on WD's and 45's?
Edited by CTuckerNWIL - 18 Feb 2012 at 9:10am
This page was generated in 0.067 seconds.
