WD/ D15 industrial wheel swap
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: WD/ D15 industrial wheel swap
    Posted: 31 Jan 2022 at 6:22am
I’m seriously considering buying an I600 backhoe.
It’s sitting on some property way back in the woods with a bad tire. I’m wondering if I could use my WD45 wheels n tires to get it home.?
Not sure if the bolt pattern is the same.
I’m fairly sure a D15 and WD45 are the same but wondering if the industrial is the same?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2022 at 7:05am
   the industrial may have lug bolts with a larger head. The bolt circle and pilot hole will be the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2022 at 7:16am
Thank you
This page was generated in 0.588 seconds.
