WD cultivator question
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Topic: WD cultivator question
    Posted: 09 Jul 2011 at 12:49pm
Lets start with I'm not a farmer so I've never mounted a cultivator. I picked up my WD today and I'm installing my $25 cultivators on it. Everything is good except for the drawbar area, is my drawbar thing wrong or am I missing the picture? It says to remove pins that hold drawbar bail from pivoting, but when I do that it falls off the tractor. Any input appreciated.  Thanks
Tom K Ind. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom K Ind. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 1:02pm
      Yes the drawbar assembly stays off ,and the two arms connect to the drawbar carrige holes.
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 1:06pm
WD drawbar bails, at least the early ones, didn't have the slots on the end of the bail. They had a hole with a bolt through it. Many of the rear-mounted implements on the pin hitch WD's mounted to the drawbar, and the bail stayed on the tractor, with the lower pins removed, which allowed the drawbar to move up and down with the implement. I would either find a different bail, or fab a piece to close up the slot and bolt it to the bail with a 1/4" bolt in holes drilled through the end of the slot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 1:13pm
Dave, that's what I was thinking, the slots on the end are what's screwing me up. Maybe the bolt trick will work.
Edited by MNLonnie - 09 Jul 2011 at 1:13pm
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 1:15pm
This might help you get it on there. I leave the draw bar on the tractor.
Here a pic of the back bar and a link to all my pics of the unit mounted on a WD45.
Hope this helps. Don
Edited by Don(MO) - 09 Jul 2011 at 1:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 1:27pm
That might work for me also Don.  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 3:02pm
Got it all mounted up and it goes up and down so must have done something right. Bought it as a pile of stuff that was supposed to be complete and the only thing missing is the depth stop rod for the rear bar, that's pretty good, probably find one at hutch if I remember to look. Thanks for the ideas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 4:29pm
Lonnie, Please post a pic how you get it installed.
Thanks, Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 5:09pm
I ended up taking the pin out of the end of the arm so I could bolt it to the drawbar bracket.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 8:36pm
Brings back some old memories.  We had mounted a cultivator on a WD and were going around to field to properly adjust it.  I was riding with my foot on the draw bar bail which went up and down with the rear furrowing bar.  When he lifted the cultivator my foot became wedged and I would have been crushed.  I yelled the farmer put his foot on the clutch.  It stopped.  He left it down and I was freed with an OK foot.
I have loved the hyd pump behind the clutch ever since.  Saved my foot.
You know, I get goose bumps just thinking about that.
Somebody up there loves me!!!
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2011 at 8:49am
If I'm looking at your pic right it looks like you will need to get the angle bracket that mounts on the cly mount too. Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2011 at 9:21am
You're right Don, figure if I find the rod with the stop I can make the angle, I have several tons of angle laying around in all shapes and sizes. I considered making the rod and collar but decided not to since the cultivator will probably never be used.
Edited by MNLonnie - 10 Jul 2011 at 9:27am
This page was generated in 0.336 seconds.
