WD crackshaft end thrust |
savedallis1953
Topic: WD crackshaft end thrustPosted: 09 Mar 2019 at 6:06am |
Could anyone tell how to adjust for end thrust in a WD? Thank you all for keeping A/C alive and well
1953 WD, 1953 WD, WD engine with WD-45 crankshaft.
savedallis1953
Posted: 09 Mar 2019 at 6:07am |
Oops Crankshaft
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 09 Mar 2019 at 8:12am |
Check with Don(MO) I believe he has some possible tips. I am sure there are other folks too.
Regards, Chris
MACK
Posted: 09 Mar 2019 at 8:15am |
Nonadjustable, replace thrust bearing. MACK
savedallis1953
Posted: 09 Mar 2019 at 9:40am |
Thanks for the information.
savedallis1953
Posted: 09 Mar 2019 at 9:57am |
Hi Mack could you tell me where the thrust bearing is, I believe I did know but that was about 20 years ago. Thank you.
Posted: 09 Mar 2019 at 10:28am |
Front main bearing is the thrust.
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2048 |
Posted: 09 Mar 2019 at 5:48pm |
I send mine out to be machined to fit the new thrust bearing.
savedallis1953
Posted: 09 Mar 2019 at 6:14pm |
Yes Thank you for jogging my memory. I am now on #7 in the W series and never really got into the bottom of these beautiful powerful engines. Building a shop almost exclusively for my small collection. I have found no other engine like it which turns 1400 rpms and makes 29 pure horses
savedallis1953
Posted: 09 Mar 2019 at 6:18pm |
I recently purchased the desired combination of a WD block with a WD-45 crankshaft and big valves, dished pistons + marvel schebler 871 carb with a 4 bolt wide front end.
