WD connecting rods
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: WD connecting rods
    Posted: 04 Jan 2016 at 10:07pm
Are the connecting rods the same between a WD and a WD 45? I know the stroke is 1/2" longer on the 45.
Thanks in advance.
The mechanic always wins.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2016 at 10:15pm
Same rods, same length.  Piston height was different.   I think 45 rods didnt use shims, WDs did so check your bearing clearances.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2016 at 10:22pm
Good point. I remember reading somewhere that the 45 had shims in the mains but not the rods. So, if I bolt the caps on the rods, without bearings, if they are WD rods, they should not be round, because they need to be shimmed. 45 rods should measure perfectly round, no?
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2016 at 10:24pm
the rods are the same. i have a nice set with pistons on if you need some. 4 inch boor .
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 7:18am
I always though rods and pistons where the same other than the dish and it was the crank that gave it the half in more piston height
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 7:36am
 A WD piston with a 45 crank ups the compression ratio way beyond what the 45 had.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 12:23pm
Wouldn't this be a little dangerous?  Blow the engine or the head?  What gives the D-17 (same block) more horses?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 1:52pm
more speed, bigger carb and taller piston
Wink
I am a Russian Bot
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 6:53pm
The 55 WD45 I just did took shims on the rods. Crank was turned 0.20 on the rods and 0.10 on the mains. Had shims when I took it apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2016 at 8:44pm
Yes, I just went and checked them, they take shims. You just never know what parts are in 60+ year old machinery......
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 9:45am
No,  compression ratios were low on the W201 to start with for burning kerosene. As things developed the CR went up a bit and engine rpm went up. By the time the 175 gasser came out they may have been 8.25:1.
 Quote from an old post in yesterdays tractors.
 "I completed this conversion on my WD45 and it worked out very well. There is a 1/4" difference in pin height between the two pistons plus the difference in piston top design (flat vs. dished) which brings the compression ratio up to 10.54:1 with a stock 4" bore, 4.5" stroke, and a .075" thick head gasket. There was still at least a 1/4" valve clearance with the WD piston tops when using the stock lift cam. I also converted the tractor to 12V, and using the stock 6V starter, it cranks and starts the engine very easily. (I am not sure how easy it would turn over on 6 volts though). It idles the same (or better) than the 6.4:1 CR WD45 engine and has noticeably more torque. I was also surprised that the exhaust was not much louder than stock. It runs fine under light loads on 87 octane gasoline but you should probably run at least 91 octane, add octane booster, or switch to E85 under heavy loads to avoid detonation. Note: If you are going to run used WD piston sleeves, make sure they do not have any top ring ridge as the pistons will now travel a 1/2" farther up the cylinder than they did with the 4" WD crank, which could break a top ring. (My sleeves were used off ebay and had a small ridge that I was able to hone out) This is a great power upgrade!"
This page was generated in 0.414 seconds.
