WD clutch |
fixer1958
Topic: WD clutchPosted: 06 Mar 2011 at 10:31am |
I yanked the clutch out of my WD yesterday. Can't say it's the easiest thing I have ever done, wasn't to bad though. Only had to crawl around on the floor a couple of times. My knee doesn't like that much.
Looked at the book when i was done to see how to do it and it said to pull the engine.
Go figure......I didn't do it that way.
Who's the best to get a 9 spring clutch set from?
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 06 Mar 2011 at 10:53am |
Which way did you do it? Always heard that pulling the engine was the fastest, or at least easiest.
AaronSEIA
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 06 Mar 2011 at 1:01pm |
OK fixer, I'll bite two how; just how did you get the clutch out without pulling the engine out?
Don
John WV
Joined: 30 Oct 2010 Location: bunker hill wv Points: 280 |
Posted: 06 Mar 2011 at 1:04pm |
yes i would like to know how you did it? I always pulled the engine
Gary in da UP
Joined: 13 Sep 2009 Location: EUP of Mi. Points: 1885 |
Posted: 06 Mar 2011 at 1:07pm |
[QUOTE=Don(MO)]OK fixer, I'll bite two how; just how did you get the clutch out without pulling the engine out?
Don [/
Well, you go in thru the tailend, kinda like you was a proctologist doin' brain surgery......QUOTE]
fixer1958
Posted: 06 Mar 2011 at 1:18pm |
I split it and unhooked all the misc crap. Unbolted the pressure plate and disc and put it in the bellhousing. Used a 3/8 ratchet and a pipe cheater to unbolt the flywheel. I then tied a rope around the flywheel and wiggled it loose so it wouldn't hit the concrete. Unhooked the spring for the throwout bearing and took it off. Alot of it was done through the starter hole.
I will reassemble in the reverse order as any manual says. The only problem I forsee is the disc alignment. I have about 50 alignment tools at work for cars and trucks, I'm going to see if one of those match reasonably well or use a mirror. I had done this about 15 years ago on another WD. I was thinking at the time that this is sure a PITA for a clutch.
You have 5" of clearance between the block and bellhousing. Enough plus an inch to get the flywheel out.
It took 3 1/2 hours.
mooboy
Posted: 06 Mar 2011 at 5:13pm |
You are a fast worker Fixer1958, never seem to get a job that big done in 3 1/2 hours.
fixer1958
Posted: 06 Mar 2011 at 5:37pm |
3 1/2 hours to remove it.
Still in piles till I find another clutch.
Anyone have any suggestions for a 9 spring clutch set?
