Wd Clutch |
fixer1958
Topic: Wd ClutchPosted: 20 Oct 2010 at 1:54pm |
Doesn't a WD and WD45 pressure plate interchange?
Considering going with a 9 spring pressure plate.
Has anyone ever used a button clutch disc in one?
I put a button clutch in an old dump truck I had and you didn't slip the clutch much.
It was either in or out.
Just wonder how it would be in a WD.
Posted: 20 Oct 2010 at 5:34pm |
Yes, the PPlates interchange......you have to use the 4-button type (from a K Gleaner fits) in a puller if you get over 75 HP or so. Yes, they are aggressive. You may not like if for farm use.
norm [ind]
Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
Posted: 20 Oct 2010 at 7:24pm |
will wear flywheel for sure never sold one for that reason
