WD Clutch
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Topic: WD Clutch
    Posted: 05 Oct 2019 at 3:37pm
When I drive our WD I need to block the handclutch or else it will go to ‘neutral’
Do you guys know how I can adjust it?
Thanks!
Edited by Wot - 05 Oct 2019 at 3:45pm
AC: B / WD / CA / WC unstyled / U / 7060 / 710
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2019 at 10:11pm
Remove cover, with clutch engaged, remove big snapring at back. Release clutch, then turn pressure plate where snapring was about 1/8 turn. Engage clutch and replace snap ring.
Before doing that, make sure there are no pins missing out of any linkage.    MACK
