WD clutch slip
MBolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBolton Quote  Post ReplyReply Direct Link To This Post Topic: WD clutch slip
    Posted: 08 May 2010 at 12:05pm
I' v owned this WD for over 12 years. It must not have been used for a long time when I bought it as the clutch was grabby until used for a while then it straightened up. But,,,, under heavy load it seems to slip to the point that the tractor stops. Works good at all other times; with the loader, plowing snow, light to heavy loads but the tractor stops under very heavy load.
Before I tear into it I'd like some guidance. Do I start with the hand clutch (It "pops" over center real well) or the engine clutch?
Ken
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 12:14pm
hand or foot clutch
160 CA 920diesel 5020 HD-3
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 1:32pm
Turn the PTO on and see if the PTO slows down too when the clutch slips.  If it does, then it's the foot clutch, if it remains at a constant speed when the tractor begins to slow down from the slipping clutch, it's your hand clutch slipping.
Hurst
1979 Allis Chalmers 7000
5800 Hours
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 1:50pm
I ruined one 45 when we loaded on a trailer, the rear main was bad and the angle was enough to soak it. It slipped for about 14 years and dynoed 15 horse less than before.
   The other 45 , I assume I over filled hydraulic oil and the vent oiled it for me while playning with stuck loader cylinders. That engine is coming out to go in the WC anyway now. I do have a simple permanent fix for that issue.
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
This page was generated in 0.445 seconds.
