WD clutch pedal
Huolti View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Huolti Quote  Post ReplyReply Direct Link To This Post Topic: WD clutch pedal
    Posted: 02 Apr 2020 at 3:51pm
Restoring a WD. trying to get transmission clutch pedal off so I can put some bushings in it. Can not just slide it off as the tractor frame is in the way. Any suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2020 at 7:45am
If need be, you can take one frame rail clear off, as long as it's sitting still
 Moved to Farm Equipment page from "Forum Talk".
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2020 at 7:59am
Might take a big breaker bar to crack the rear bolts in the frame rail.
Wink
I am a Russian Bot
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2020 at 8:15am
Take brake pedals loose and slide shaft to right side.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2020 at 2:57pm
yep What MAC said. Check shaft for wear too. Usually half of the wobble is wear in the shaft too.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 7:38am
Everyone I do gets a new shaft, right brake pedal and engine clutch pedal bushed.
