WD Clutch Install
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 6:59am
First it sounds like you don't know which clutch is slipping. Put the PTO in gear and watch to see if it stops when the tractor stops when pulling. If it stops then the foot clutch is slipping. If it doesn't stop then the hand clutch is slipping. I've had one that were both bad at the same time. After you determine which clutch you are working on then we can more easily help you.
Edited by Lonn - 02 Oct 2017 at 7:02am
Wink
I am a Russian Bot
jboettcher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jboettcher Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 9:37am
Thank you everyone for the clutch respones!!  I think I got it.
What are your oponion on plugging the crankshaft and replacing the oil wick with a sealed bearing?
What is everyone using to PLUG the crankshaft?
Does anyone have a failsafe part number for the sealed bearing?
Thanks!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jboettcher Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 9:39am
As I continue research, I saw this note on the sealed pilot bearing.
""Pilot Bearing that fits Allis Chalmers Tractor Models:G138, G160, G226, RC, WC,WD (Engine S/N <45-30955), WD45 (Engine S/N <45-30955), 170, 175 Bearing Sides: 1 Non-Contact Metal Shield, Bore: .984" (24.993mm), OD: 2.047" (51.993mm), Width .591" (15.011mm)""
My SN# is 4XXXX
