WD Clutch Install
jboettcher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jboettcher Quote  Post ReplyReply Direct Link To This Post Topic: WD Clutch Install
    Posted: 25 Sep 2017 at 10:16am
I am looking to find someone that is in Wisc that would be interested in a side job installing a clutch assembly in my WD when I remove the motor.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 10:26am
Removing the engine is way more work than the installation of the clutch.  After the engine is out it's a piece of cake.  Remove the old clutch and take it to a clutch rebuilder in your area or have one of the fine folks that support this site do it.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote jboettcher Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 10:33am
WHere would I find who in wisconsin does the clutch work
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 10:38am
Yellow pages or Google or check with the vendors on this site.
1968 one-seventy
1956 F40 Ferguson
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 10:46am
Talk to Rick! He's on here most days I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jboettcher Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 10:51am
OK! Call slap me silly and call me Shirley!
I don't see anything calling out vendors? Any assistance would be great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 11:22am
Go to top of this page and select/click on the AC emblem.  It should take you to another page that has "parts and Services" listed on one of the tabs.  Select it and you will see the vendors.  I don't think Rick is listed there but he is the resident clutch expert and should be along shortly.
1968 one-seventy
1956 F40 Ferguson
jbirnsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 11:32am
I just bought a clutch disk of off eBay (search for price + shipping lowest) and you can also get an aliment tool there too. There are only a couple of bolts that hold the pressure plate on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 12:38pm
Get with Rick Corder. He's in Missouri but he will ship just about anywhere. I'd have him send you a cover and disc. I'm sure he'd want your old ones to rebuild for the next guy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jboettcher Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 12:57pm
OK Rick. He and I have been talking on FB Messager
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 1:39pm
Would suggest buying a service manual also-this is in addition to and not to be confused with an operators manual (which you should also have).  Easy to follow instructions there.
Thanks
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 2:41pm
Easy peasy. I helped do it when I was a whippersnapper. Once the engine is out you essentially unbolt the pressure plate and remove the clutch disk. Replace the clutch disk and maybe the pressure plate. I suggest that you replace the throw-out bearing, but that's no big deal either. Use a centering tool to center the disk. It's a little bit of a bugger aligning the splines when you reinstall the engine, but a little patience does the trick.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 3:19pm
Don`t  forget  to check the  step  in flywheel...     Tony
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 3:26pm
Jamie...Tony brings up a very good point! ALWAYS resurface the flywheel or you might as well just keep the old clutch in there! The step is 1.188 in the book...close enough at 1.187 or 1 3/16".   Rick
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 4:19pm
And don't force the engine back in using bolts. It should slide together with some maneuvering. Make some lineup dowels but cutting off the heads of a couple longer bolts to assist.
Edited by Lonn - 25 Sep 2017 at 4:21pm
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote jboettcher Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 5:03pm
I may be confusing myself.
Is the engine clutch basically 3 pieces? and bolts onto the flywheel like a car?
I think I have been looking at the transmission clutch and confusing that with the encine clutch.
I never had a slip issue with the PTO, we only pull plows and planters. which clutch system drives the rear wheels? Engine clutch or transmission clutch? Also, we typically (only) use the hand clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2017 at 5:24pm
The engine clutch drives everything. The transmission clutch, under the battery box, disengages the transmission so the wheels can stop, but lets the PTO and hydraulic pump keep working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2017 at 7:53am
If you mean the hand clutch, there's an excellent YouTube video that someone here posted a couple of months ago. I'm old and getting the heimers, so I don't remember who posted it. Verniers and calipers and such can usually be rented.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2017 at 9:00am
You should really only use the foot clutch. The hand clutch is only to stop forward motion while allowing the  PTO or hydraulics to continue running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jboettcher Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2017 at 6:38am
I’m just tossing this out there
I possibly found an engine in KY, I’m just curious if anyone has a WD or WD45 engine closer to Wisc .
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2017 at 3:35pm
I will never understand that line of thinking.
DanC911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2017 at 9:04pm
Here is the link: https://youtu.be/1ebh4pRvTiI
Post Options Post Options   Thanks (0) Thanks(0)   Quote jboettcher Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2017 at 6:11pm
This is getting rediculous.   Does nobody know how to replace/install/set up an engine clutch on a WD?
I’ve got lots of messages saying it’s so easy, but no instructions.
What is the height, how many shims, how far can flywheel be machined?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2017 at 10:13pm
now i am getting confused,   engine clutch just bolts to  the flywheel with a piolet to center the disc springs facing out  tighten all the bolts down even , somone on here probley that torque spec in the new piolet bearing installed in the center of the flywheel only dimension to worry about is the step in the flywheel when it is re serfaced ,that was posted earlyer.  thats about all there  is to it.       keep the greasey finger prints of the mating surfaces.    the hand clutch is the one that has the shim packs
Post Options Post Options   Thanks (0) Thanks(0)   Quote jboettcher Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2017 at 10:53pm
HudCo thanks
I’m feeling a bit more informed. BUT!!!!!
HudCo’s response spurred a question. Does the engine clutch ever disengage? What engages and disengages the engine clutch?some people have said the hand clutch runs the engine clutch. The repair procedure even talks about the hand clutch free play when replacing the engine clutch
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2017 at 8:04am
Please read this quote above and buy  SERVICE & OPERATORS MANIALS it will be a big help with all the questions you have today and on down the road. Big smile
But for today's help you can send me a PM and I will send you my phone # to help you out.Wink
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 11:52am
HudCo thanks
Why would you have an engine clutch if it never disengaged? When you push the foot pedal on the left side forward, the engine clutch disengages and stops ALL power to EVERYTHING behind the engine.
 The had clutch is a transmission clutch which only stops power to the tranny  and leaves the PTO and hydraulic pump running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jboettcher Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 4:08pm
CTucker-
Ok, so if I’m pulling, and I feel “something like a clutch” slip, without the use of a pro.   What is slipping?   The transmission or engine clutch. I completely accept that I may be asking the question wrong.
Very randomly, when we are working the tractor like a team of rented mules, we will feel something slip and our forward progress slows.
Can you help me with this?
Thank you in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote jboettcher Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 4:13pm
CTucker-
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 4:25pm
if your hand clutch pulls in hard and snaps out with a bang it is probably tight enough to not slip IF the discs are not worn out.When friction surface is shot,they can be tight and still slip.
