WD chisel plow
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: WD chisel plow
    Posted: 22 Nov 2018 at 8:34pm
In general, does the WD have enough guts to pull a single chisel plow with a plug behind it to create a drainage tunnel??
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 9:10pm
Not very deep.       MACk
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 9:16pm
Just out of curiosity, is a single chisel plow with a plug the same thing as a subsoiler with a mole?
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 9:13am
My guess is it would do ok down to about 18-20 inches. And it will depend on the soil. I assume your working in clay as that is what your typically trying to drain with one of these units. It may make the old WD snort a little. Front might be a little light?:) Need pictures when you get going. I think there are pictures of guys using these on here in a thread. Might search subsoiler or chisel plow??
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 6:15pm
My #4 subsoiler with mole will give my WD45  all it wants to handle when set at about 18 inches deep in most all soil types in second gear and some times have to down shift into first.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2018 at 9:11pm
Had to throw a big bag of sand on the front of the hood when I did it 44 years ago! Fixed the drainage problem , tho!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2018 at 3:46pm
Thanks I'll try it
