WD change to distrubtor? |
alleyyooper ![]() Orange Level ![]() Joined: 12 May 2014 Location: Michigan Points: 238 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Jan 2018 at 4:59am |
Can a Wd with a mag be changed over to a distrubtor?
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
We had one when I was a whippersnapper 50+ years ago. I don't know how available a kit would be today. At the very least I'd think you could find one at a bone yard. A WD45 distributor would fit. I don't know if a distributor off a D series tractor would fit or not.
SteveMaskey(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wellsville, MO Points: 617 |
Yes, put a wanted add in the classified section I am sure one of the vendors will have a distributor
ac45dave ![]() Orange Level Access ![]() ![]() Joined: 23 May 2015 Location: SE(IN) Points: 1346 |
Give steve at b&b circuits a call.he can rebuild your mag or set ya up with a distributor.last i checked he had distributors on the shelf ready to go.http://www.bb-customcircuits.com/ http://www.bb-customcircuits.com/apps/webstore/products/category/1108835?page=1 http://www.bb-customcircuits.com/apps/webstore/products/category/1108880?page=1
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12005 |
We offer a complete Mag to Distributor kit if interested. Check out our website. Gives you everything in the kit to do the changeover except ambition. Thanks Dave for posting the site! You da' man!
![]() Steve@B&B |
jiminnd ![]() Orange Level ![]() Joined: 16 Sep 2009 Location: Rutland ND Points: 2303 |
I have an IH distributer on my WD, was put on when I was kid so been there for 60 years or so.
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
Steve, what did you do with the ambition ? I could use some.
Dusty
Roger (NE) ![]() Bronze Level ![]() Joined: 14 Oct 2010 Location: Nebraska Points: 186 |
Converted our WD's and styled WC's from magneto to distributor ignition back in the 60's when I was "young". If I remember right those kits were available from TSC at that time. Before the internet so you went to a local store to buy parts or repairs back then. Great memories of past times when things were so much more simple!
Bill Deppe/AC Salvag ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 974 |
Would have a couple units $125.00+ s&h Ia 563 357-2615
TramwayGuy ![]() Orange Level Access ![]() Joined: 19 Jan 2010 Location: Northern NY Points: 11755 |
There are several on EBay right now. Was a popular conversion on its day.. unbolt the mag and bolt on the conversion, change the ground wire to a switched battery-supplied wire and time it properly.
ac fleet ![]() Orange Level ![]() Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
I just put a wd dist. on one of my c tractors. seeeems to run fine, once timed right! thanks; ac fleet
Phil48ACWC ![]() Silver Level ![]() ![]() Joined: 17 Jan 2013 Location: Vermont Points: 305 |
Those look pretty well worn. I'd either get a refurbished one from someone I know or plan on replacing all the bushings and springs myself. |
alchpuller ![]() Bronze Level ![]() Joined: 17 Dec 2015 Location: Goddard ks Points: 30 |
Your mag can be used as a dist. the grd. wire hooked to _ side of coil, other end to points, your points and condenser act just like it would in a dist.fields and arm.
not used, coil wire goes to shaft that goes to rotor, you have to cut out case and put a eye on end of coil wire, it will time just like a mag,points are usually good condenser might be bad, that fixes a lot of mag`s |
