WD change to distrubtor?
alleyyooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alleyyooper Quote  Post ReplyReply Direct Link To This Post Topic: WD change to distrubtor?
    Posted: 21 Jan 2018 at 4:59am
Can a Wd with a mag be changed over to a distrubtor?
Big smile   Al
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2018 at 5:45am
We had one when I was a whippersnapper 50+ years ago. I don't know how available a kit would be today. At the very least I'd think you could find one at a bone yard. A WD45 distributor would fit.  I don't know if a distributor off a D series tractor would fit or not.
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2018 at 6:13am
Yes, put a wanted add in the classified section I am sure one of the vendors will have a distributor
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2018 at 8:10am
Give steve at b&b circuits a call.he can rebuild your mag or set ya up with a distributor.last i checked he had distributors on the shelf ready to go.http://www.bb-customcircuits.com/      http://www.bb-customcircuits.com/apps/webstore/products/category/1108835?page=1      http://www.bb-customcircuits.com/apps/webstore/products/category/1108880?page=1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2018 at 8:26am
We offer a complete Mag to Distributor kit if interested. Check out our website. Gives you everything in the kit to do the changeover except ambition. Thanks Dave for posting the site! You da' man!   Thumbs Up
Steve@B&B
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2018 at 9:20am
I have an IH distributer on my WD, was put on when I was kid so been there for 60 years or so.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2018 at 9:22am
Steve, what did you do with the ambition ?  I could use some.
Dusty
Roger (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2018 at 9:36am
Converted our WD's and styled WC's from magneto to distributor ignition back in the 60's when I was "young". If I remember right those kits were available from TSC at that time. Before the internet so you went to a local store to buy parts or repairs back then. Great memories of past times when things were so much more simple!
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2018 at 12:18pm
Would have a couple units $125.00+ s&h  Ia 563 357-2615
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2018 at 12:26pm
There are several on EBay right now. Was a popular conversion on its day.. unbolt the mag and bolt on the conversion, change the ground wire to a switched battery-supplied wire and time it properly.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2018 at 6:53pm
I just put a wd dist. on one of my c tractors. seeeems to run fine, once timed right! thanks; ac fleet
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2018 at 5:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2018 at 6:04am
Originally posted by Phil48ACWC Phil48ACWC wrote:
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR1.TRC0.A0.H0.XAllis+Chalmers+distributor.TRS0&_nkw=Allis+Chalmers+distributor&_sacat=0
Click on above.
Those look pretty well worn.  I'd either get a refurbished one from someone I know or plan on replacing all the bushings and springs myself.
alchpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alchpuller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2018 at 11:31am
Your mag can be used as a dist. the grd. wire hooked to _ side of coil, other end to points, your points and condenser act just like it would in a dist.fields and arm.
not used, coil wire goes to shaft that goes to rotor, you have to cut out case and put a eye on end of coil wire, it will time just like a mag,points are usually good condenser might be bad, that fixes a lot of mag`s
This page was generated in 0.219 seconds.
