WD belt pulley |
exSW
Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Topic: WD belt pulleyPosted: 05 Jul 2023 at 8:01am |
How does it come apart? I had one give to me that's locked up solid. It's been soaking in a five gallon bucket of kerosine and atf for at least 6 or 7 months. Looks like theres a lock ring on the gear side holding in a roller bearing. There is a breakdown in the manual. Any tips?
Edited by exSW - 05 Jul 2023 at 8:02am |
Learning AC...slowly
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4942 |
Posted: 05 Jul 2023 at 8:28am |
this is out of my WC manual, but it's the same assembly ![]() |
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
exSW
Posted: 05 Jul 2023 at 9:57am |
That's pretty straightfoward. My manual had a different graphic and no explaination. Thank you.
I don't suppose anyone has the part numbers for the bearings and seals? Or knows where to look. Edited by exSW - 05 Jul 2023 at 12:00pm |
JoeM(GA)
Posted: 05 Jul 2023 at 12:17pm |
71135475 BEARING, ball, outer shaft
70210025 BEARING, ball, inner shaft 70208417 Oil Seal Outer Bearings should have numbers on them that will work at a parts or bearing store, seal should too
exSW
Posted: 05 Jul 2023 at 2:38pm |
THANK YOU!
exSW
Posted: 27 Jul 2023 at 10:57am |
I've got it apart,steam cleaned,bead blasted,primed,painted,bearings(sealed) are here and going back together. BUT the interior shaft snap ring must have lost it's temper to the acetalyne wrench. Does it have a part number or spec?
exSW
Posted: 27 Jul 2023 at 11:03am |
Oh, sealed bearing #'s
FAG 6207-2RSR FAG 6208-2RSR One was German one was Korean. $41.00 plus tax shipped. On Ebay. And I did have to throw the bearings in the freezer overnight.
Edited by exSW - 27 Jul 2023 at 11:06am |
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11411 |
Posted: 28 Jul 2023 at 1:35pm |
I have 2 of these pulleeys that I would sell in Ohio. I think they both need some work from setting around.
exSW
Posted: 31 Jul 2023 at 8:40am |
I've been digging looking for this snap ring. Fastenal,Macmaster Carr,Ebay no gots.
JoeM(GA)
Posted: 31 Jul 2023 at 9:12am |
#9 ![]() |
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11858 |
Posted: 31 Jul 2023 at 10:37am |
“..Does it have a part number or spec?..”
Measure the shaft diameter (not the groove), and that will tell you what the snap ring size should be. There is often a choice of ‘standard’ or ‘heavy (thicker)’. If the bearings listed in an above post are correct, the shaft diameter is 40mm; so it will either be a 40mm ring, or maybe a 1-9/16”. Both are readily available from McMaster-Carr. Edited by TramwayGuy - 31 Jul 2023 at 10:42am |
exSW
Posted: 01 Aug 2023 at 8:07am |
None standard thickness. Like 4mm. I got a part nu mber and found one at a dealer.
