WD battery cable question
jarrod318 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jarrod318 Quote  Post ReplyReply Direct Link To This Post Topic: WD battery cable question
    Posted: 14 Jul 2016 at 8:58am
Hello Guys - My WD is not starting up and I believe I need new cables, but wanted to run it by the pro's. The battery is newer and the charger said its ok, when I attach the charger to the cables it states "charging aborted-bad battery". The cable connectors are cracking,so I assume that is why I am not getting a spark?
I have had some sparking from the battery posts in the past along with replacing a starter twice in two years. Not sure this factors in but more the info the better.
As always, thank you for lending the knowledge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jarrod318 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 9:21am
It is a 12V battery
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 9:39am
You should never have sparking anywhere. All connections should be totally tight. First clean up all cable connections. Clean at both ends, including unbolting from the starter stud as well as the ground bolt on the frame. Clean the connections and terminals with a rotary brush attached to a drill motor. Everything should shine with a bright gleam when you are finished. Reconnect everything tightly and try it again. Report the results to us.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 9:43am
What Doug said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jarrod318 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 9:45am
Thanks Doug, I will jump on that and report back. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 6:02pm
First thing you should do is draw test the Battery to insure the Battery is good first. Then do what Doug mentioned if the Battery passes the draw test. A bad Battery can cause the issues you are having also... HTH
Steve@B&B
This page was generated in 0.773 seconds.
