wd axle removale
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: wd axle removale
    Posted: 18 Sep 2023 at 10:20pm
do the brake shoes have to come out to remove the axles
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2023 at 1:22pm
Yup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 9:24pm
Let the fun begin.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 9:49pm
The brake pins will be your first fun job. I soaked mine for a few days with Kroil, sprayed the pins through the access hole. Tapped on them a few times and they came loose. Used the puller but they were very easy to get out. Hope that first step goes well for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2023 at 9:53pm
its a rusty one it has sat outside for 50 years not running and no more room for one more mouse  but i am after 1st 2nd gear for the wc puller transmission
fo
e
ng
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2023 at 6:22am
I have a couple buckets full of WD gears I would sell if interested.
http://lonsallischalmers.com
This page was generated in 1.465 seconds.
