WD axle bearing |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8667 |
Topic: WD axle bearingPosted: 25 Feb 2016 at 1:31pm |
The hard part is done.
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 25 Feb 2016 at 1:05pm |
Yes sir you are correct. I might was well pull the whole thing off since I already have the brakes out of it.
Charlie
CTuckerNWIL
Posted: 25 Feb 2016 at 12:56pm |
Do you mean the outer pinion shaft bearing? If that is the one you are referring to, it could be replaced, if you can get the race out and then pull the bearing. I don't know how much room there is to work in there.
The outer axle bearing is between the Hub on the axle and the final drive bull gear and the pan and axle would have to come out to replace it. |
Charlie175
Posted: 25 Feb 2016 at 12:32pm |
I need to replace the top outer bearing on the axle shaft. Can this be done without removing the shaft?
Charlie
