WD and WD-45 Original Sediment Bowl Height |
wjohn
Topic: WD and WD-45 Original Sediment Bowl HeightPosted: 31 Dec 2024 at 12:43pm |
Two questions that I can't find have been asked before:
1. Did the WD and WD-45 use the same size sediment bowl? (I don't want to assume...) 2. What is the correct height of sediment bowl? Most aftermarket vendors now sell "short" and "tall" bowls. Both will fit. My WD owner's manual seems to show a short bowl. I don't think I've seen an original fuel strainer assembly that survived since they tend to leak and get replaced over the decades. I'm guessing some of you guys on here have seen them before and would know for sure.
BobPaulusCentrOH
Bronze Level Access
Joined: 11 Sep 2009 Location: Lancaster, Ohio Points: 178 |
Posted: 31 Dec 2024 at 1:08pm |
WD-45 Gas used a short one same as WD.
jvin248
Posted: 31 Dec 2024 at 7:01pm |
. I've seen more tall bowls on farmalls. If you have a rusty fuel tank then use a tall bowl. Or if refurbishing a working tractor vs chasing a museum factory stock tractor the tall bowl can give future protection. .
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8667 |
Posted: 31 Dec 2024 at 8:27pm |
My (dad's) original 49 WD has a short bowl just like my unmolested 56 WD-45
garden_guy
Joined: 05 Jul 2013 Location: Illinois Points: 1153 |
Posted: 31 Dec 2024 at 10:20pm |
Fairly certain it's a short bowl. Both my WDs and the WD-45 I worked on had 'em.
From my WD: ![]() ![]() From my cousin's WD-45 (same bowl): ![]() |
wjohn
Posted: 01 Jan 2025 at 8:03am |
Short bowl it is. Thanks all!
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1104 |
Posted: 02 Jan 2025 at 10:55pm |
My 57 45 had a short aluminum sentiment bowl…
Think it got replaced at some point in life but heck, never knew that there was aluminum bowl!! |
ac hunter
Posted: 03 Jan 2025 at 7:26am |
I think the aluminum bowl was used with a mounted corn picker so as to reduce the chance of the bowl getting broken and causing a fire. Am I right?
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1790 |
Posted: 03 Jan 2025 at 7:56am |
Yes
Dennis J OPKs
Joined: 12 Sep 2009 Location: Overland Park, Points: 543 |
Posted: 03 Jan 2025 at 9:12am |
I don't remember fires being common back in the old days. We did have a fire extinguisher on the picker (snapper as the red & green folks called it) but then again, nothing was plastic.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12019 |
Posted: 03 Jan 2025 at 9:24am |
As the guys said, short bowl was normal. The Taller bowls hold a little more fuel and also trash in the fuel. Having a taller or "deeper" bowl helps keep trash farther away from the inlet in my opinion. Totally optional.... Steve@B&B
BigGuy1000
Posted: 03 Jan 2025 at 5:29pm |
Yes, you are right about the aluminum bowl, I still have that although I have replaced it with the original short glass bowl, but I remember my father and uncle(they owned the tractor) commenting that the dealer had come out to replace the glass bowl(such service!) with that bowl because of the danger of fire on the 170 with mounted picker.
