WD and WD-45 Original Sediment Bowl Height
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: WD and WD-45 Original Sediment Bowl Height
    Posted: 31 Dec 2024 at 12:43pm
Two questions that I can't find have been asked before:
1. Did the WD and WD-45 use the same size sediment bowl? (I don't want to assume...)
2. What is the correct height of sediment bowl? Most aftermarket vendors now sell "short" and "tall" bowls. Both will fit.
My WD owner's manual seems to show a short bowl. I don't think I've seen an original fuel strainer assembly that survived since they tend to leak and get replaced over the decades. I'm guessing some of you guys on here have seen them before and would know for sure.
BobPaulusCentrOH View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobPaulusCentrOH Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 1:08pm
WD-45 Gas used a short one same as WD.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 7:01pm
I've seen more tall bowls on farmalls.
If you have a rusty fuel tank then use a tall bowl.
Or if refurbishing a working tractor vs chasing a museum factory stock tractor the tall bowl can give future protection.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 8:27pm
My (dad's) original 49 WD has a short bowl just like my unmolested 56 WD-45
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2024 at 10:20pm
Fairly certain it's a short bowl. Both my WDs and the WD-45 I worked on had 'em.
From my WD:
From my cousin's WD-45 (same bowl):
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 8:03am
Short bowl it is. Thanks all!
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2025 at 10:55pm
My 57 45 had a short aluminum sentiment bowl…
Think it got replaced at some point in life but heck, never knew that there was aluminum bowl!!
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 7:26am
I think the aluminum bowl was used with a mounted corn picker so as to reduce the chance of the bowl getting broken and causing a fire. Am I right?
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 7:56am
Yes
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 9:12am
I don't remember fires being common back in the old days.  We did have a fire extinguisher on the picker (snapper as the red & green folks called it) but then again, nothing was plastic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 9:24am
As the guys said, short bowl was normal. The Taller bowls hold a little more fuel and also trash in the fuel. Having a taller or "deeper" bowl helps keep trash farther away from the inlet in my opinion. Totally optional....
Steve@B&B
BigGuy1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 5:29pm
Yes, you are right about the aluminum bowl, I still have that although I have replaced it with the original short glass bowl, but I remember my father and uncle(they owned the tractor) commenting that the dealer had come out to replace the glass bowl(such service!) with that bowl because of the danger of fire on the 170 with mounted picker.
This page was generated in 0.107 seconds.
