WD and WD45 Engine
codyrandall21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote codyrandall21 Quote  Post ReplyReply Direct Link To This Post Topic: WD and WD45 Engine
    Posted: 22 Jun 2020 at 11:23am
I bought a house a couple of years ago. It came with a WD sitting in the barn with a blown rod. I haven't had the time to deal with it. I just found a Craigslist posting in my area for a complete WD45 Engine for $350. I've done a bit of reading and it looks like the WD45 Engine will direct fit into my WD. Is that correct? Also, while I have your attention, does it sound like a fair price? Anything I need to be weary of? Thanks for your help and expertise.
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2020 at 12:26pm
Cody - yes, it will bolt right in.  The air cleaner hose is bigger on a 45, so if you're running the 45 carb, you'll have to rig it up or change-out with a 45 air cleaner.  As for things of which to be weary, it'll be difficult to assess unless you can see & hear it run.  Most any of the issues - blow by, low oil pressure, etc. require running to test.  You could do a compression test to get some idea of it's condition.  Inspect the manifold for cracks and burnout too.  Overall, they're good reliable engines. $350 for a good, complete running engine seems like a fair/good deal to me.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2020 at 6:32pm
There is a BIG difference between running and non-running !   If I was in your situation I would consider paying $350 for a non-running engine if it came with all acc. (gen, carb, dist, and as said above air cleaner if you plan on useing the WD45 carb. Keep us posted.
wide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wide Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2020 at 12:39am
I hear the WD has a magneto and the WD45 has a distributor.
 Can these be swapped from one engine to the other?
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2020 at 7:10am
My dad bought a new '53 WD. It came with a battery ignition.
Dusty
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2020 at 8:47am
According to my notes; Battery ignition for the model WD started at serial no. 136318. Yes the distributor/mag can be switched between the models. Personally, not a big magneto fan. I'm sure they work fine if everything is 'right'. Distributor seems to be more forgiving.
This page was generated in 0.106 seconds.
