WD and A 7000 monitor ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: WD and A 7000 monitor ?
    Posted: 12 May 2022 at 8:11pm
Can a monitor be run on a WD's original 6 volt battery system if another battery was added  ?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2022 at 8:20pm
No reason why not if you have 12V to it.                      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2022 at 8:22pm
But a factory WD was/is 6 volt ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2022 at 8:54pm
you said "add another battery".... thats 12 volts !
best would be to install a 12v battery and new coil ( if its a distributor) and run it that way.. generator should charge a 12 v battery
Edited by steve(ill) - 12 May 2022 at 8:57pm
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2022 at 5:20am
What about the positive ground?
Learning AC...slowly
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2022 at 5:37am
Easy way is just hang a 12v battery on the tractor some where and charge it with a battery charger every so often.  Can't imagine an old school monitor needing that much juice.  You'd need to make the tractor 12v negative ground if you wanted to charge a 12v battery.
AaronSEIA
