WD Allis running rough and rich! |
danr
Joined: 17 Jun 2010 Location: KendalviIle, IN Points: 31 |
Topic: WD Allis running rough and rich!Posted: 19 Aug 2020 at 8:15pm |
WD Allis Chalmers running rough: Compression on cylinders 1 through 4 is 100, 100, 70, and 100 psi respectively. Plugs cleaned (before and after compression check and they were very sooty both times telling me that it is running extremely rich), plug gap set at .30, points gap set at .20. (Fuel system cleaned and fuel flowing well with new gasoline). By switching carburetor and making adjustments to it and by switching coil it didn't make any difference. Adjusted timing to no avail.
Governor working properly. Tractor just seems to spit and sputter but stays running. Anyone else had similar issue? I took audio/video of it running but I am unable to attach it. I can email or text the video if need be. |
Boss Man
Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Posted: 19 Aug 2020 at 9:23pm |
How does it run with the air cleaner disconnected?
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7534 |
Posted: 19 Aug 2020 at 9:30pm |
As mentioned above, unhook the air hose coming from the air cleaner - could be plugged. Based on what you have indicated, adjusting the carb should help smooth things out. The 3rd cylinder having 70 lbs compression is not a good sign. There should not be any more than a 10 percent variance in compression numbers. Could be a knock in the engine?
danr
Posted: 20 Aug 2020 at 5:34am |
Sorry. I forgot to mention the hose to air cleaner was renoved from the beginning of trouble shooting.
danr
Posted: 20 Aug 2020 at 5:35am |
Choke was operating correctly also.
danr
Posted: 20 Aug 2020 at 5:37am |
No knocking what so ever. Just the cutting out syndrome (spit/sputter) while running.
danr
Posted: 20 Aug 2020 at 5:43am |
I tried adjusting each carb (when assembled to engine) while tractor was running and spitting/sputtering. Didn't make a difference.
allisorange
Joined: 27 Mar 2010 Location: perkins, michig Points: 381 |
Posted: 20 Aug 2020 at 6:44am |
Maybe an intake leak? J Carlson
danr
Posted: 20 Aug 2020 at 7:51am |
I apologize.... compression is 100, 100, 90, 100.
Dan Hauter
Joined: 06 Feb 2011 Location: Carlinville, IL Points: 1269 |
Posted: 20 Aug 2020 at 4:36pm |
I have a WD that is acting just like this one. Haven't figured it out yet. Took it to a local mechanic who replaced a whole lot of little parts like plugs, points, etc. and timed it. Still runs rough.
Boss Man
Posted: 20 Aug 2020 at 5:17pm |
What does the cap and rotor look like? Look real close at the cap to see if there's any little streaks. The streaks would be carbon tracks and cause the spark to jump to where its not supposed to be.
danr
Posted: 20 Aug 2020 at 5:51pm |
Following Dan Hauter. Interested in what his mechanic finds!
MACK
Posted: 20 Aug 2020 at 9:08pm |
Been down that road before . Put a MSD 6A ING. system on it. Problem solved. MACK
Brian Jasper co. Ia
Posted: 20 Aug 2020 at 9:23pm |
CTuckerNWIL
Posted: 21 Aug 2020 at 9:12am |
Maybe you should double check the plug wires, to be sure the firing order is right.
I have 'fixed' a couple tractors that wanted to sputter and spit, after somebody did a 'tune up' on them. |
Ken McGregor
Joined: 11 Sep 2009 Location: Strathroy, Ont Points: 142 |
Posted: 21 Aug 2020 at 9:26am |
It may not always work but my WD45 was acting like that and I had replaced plugs, points, condenser, wires, etc. along with the carb tuneup and setting and nothing was working well. I finally replaced the regular plugs with NKG plugs and the problem not only went away but the tractor is firing better than I have had it work for several years. The plug number escapes me as I type but it is the standard NKG replacement for the 295 plug that AC uses. I wish I had done that sooner as I had replaced plugs several times previously but however....... Sometime the expenditure of just a little bit more money in the right place pays off. No guarantees but it sure worked for me!! regards, Ken McGregor
danr
Posted: 21 Aug 2020 at 12:33pm |
Triple cheeked them! 1243 |
Posted: 21 Aug 2020 at 12:37pm |
Clockwise rotation looking down on the rotor ?
danr
Posted: 21 Aug 2020 at 2:32pm |
Yes |
danr
Posted: 25 Aug 2020 at 8:57am |
Today I swapped out the distributor, points and condenser from another running WD I have. Started tractor up and it runs fine. When I get some "free" free time I will play around swapping rhe old points, old condenser and old distributor each separately and determine which of those three units was the culprit for making the WD spit, sputter and run rough. Thank you all for your suggestions and help in trying to resolve this matter. You are all a wealth of information and help.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12024 |
Posted: 25 Aug 2020 at 9:06am |
Chuck the Distributor you pulled out in a vise. Pop the cap off, grab the rotor and the bottom drive gear and see if it wobbles. If it does, there's your culprit. Brian nailed it if that's the case. I offer Distributor rebuilding or exchange if that's the problem if interested. Hope you find the culprit.....
Steve@B&B bb-customcircuits.com
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6089 |
Posted: 25 Aug 2020 at 12:13pm |
+1 for Brian and Steve... the distributor shaft bushing is a common wear point. Send yours to Steve to refurb.
