WD air cleaner hose |
Matt Tallant
Topic: WD air cleaner hosePosted: 10 Jan 2018 at 6:05pm |
Do they need to have the spring inside?
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3937 |
Posted: 10 Jan 2018 at 6:09pm |
None of mine have a spring inside.
acd17toy
Posted: 10 Jan 2018 at 7:28pm |
My WD parts book show a spring in the air cleaner hose. If using a soft hose a spring is needed to prevent the hose from being sucked together when throttles is pulled wide open.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3074 |
Posted: 11 Jan 2018 at 7:43am |
My steiner replacement doesn't have a spring. It hasn't sucked in yet...
Alberta Phil
Posted: 11 Jan 2018 at 9:24am |
I would think if the hose sucks in that would indicate a restriction in the air cleaner.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 11 Jan 2018 at 9:29am |
The older style hoses were SO THIN that they sucked in. The newer ones are thicker. Lots of the older radiator hoses had springs in them, but none of them do anymore as they made them thicker. The older ones you could almost stick your finger through when they were hot. Felt like much. I haven't see one with a spring in it since,,,,,,,,,,,,,,,,,back in the 60s.
