WD air cleaner gasket |
Matt Tallant ![]() Orange Level ![]() Joined: 15 Aug 2011 Location: Virginia Points: 691 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Jan 2018 at 5:31pm |
Anyone have a good source for the oil cup gasket for the WD?TIA,Matt
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8534 |
I had to make one or two. Very thin cork gasket. I can remember seeing one on the WD45 air cleaner??
Regards, Chris
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22041 |
You can find a rubber O-ring that will work just fine.
Brampton 02 gt ![]() Orange Level ![]() Joined: 07 Apr 2011 Location: Erin,ON, Canada Points: 321 |
I ordered one from ago and it is a thin felt strip. I am not sure how even to make it work. I don,t use anything and it doesn't really leak or sweat oil.
EPALLIS ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 1155 |
I'm with Brampton. Don't use one and have no issues so far.
Phil48ACWC ![]() Silver Level ![]() ![]() Joined: 17 Jan 2013 Location: Vermont Points: 308 |
I made 3 gasket rings out of a Wheaties box and stacked them up. they conformed to any regularities and sealed perfectly.
LeonR2013 ![]() Orange Level ![]() ![]() Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
The breakfast of champions.
The gasket is there for a reason. I'd imagine under load there is dust possibly being drawn in thru that area if it isn't sealed up somehow. I'm telling you, a proper thickness and diameter O-ring works really well.
polarbear ![]() Silver Level ![]() Joined: 05 Jul 2016 Location: addieville il Points: 331 |
i have two of them still available from AGCO
How is the quality?
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7514 |
Oil level in the bowl must be pretty low. I have mine filled to the mark and with no gasket, it drips out pretty steady when using the tractor. Looking at getting a gasket in the next couple of weeks. Hopefully that will help. |
from AGCO good quality
Are they cork like original?
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3072 |
Sandy Lake won't order them anymore. They say the new AGCO ones are a little too short and don't seal all the way around
they are cock well satisfied
Thanks Polarbear!!!
you are very welcome
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Spellcheck polarbear, spellcheck
Wink I am a Russian Bot |
I had no idea there was supposed to be a gasket there. Plus one more on the spell check...
opps!!!!!!!!! CORK
Edited by polarbear - 09 Jan 2018 at 12:55pm |
