WD aftermarket harmonic balancer?
danno067 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danno067 Quote  Post ReplyReply Direct Link To This Post Topic: WD aftermarket harmonic balancer?
    Posted: 05 Jan 2020 at 1:52pm
Is there a aftermarket crank damper for the 226 motor? I'm currently building a 5.75" by 4.5" motor for a customer and want to run a better front harmonic balancer. I can turn the crank snout down if need be.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2020 at 6:50am
I have made hubs to fit Fluid dampers for other motors.          MACK
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2020 at 10:26am
Fluid dampers are good, there is one I forget the name, it makes hp used in the engine masters competition.
