Wd advice
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2016 at 4:47pm
nice looking tractor.
PatrickBeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PatrickBeth Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2016 at 6:04pm
now the fun begins! Change the fluids, remember there are three differential plugs! Get all the manuals!
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2016 at 9:52pm
I think I saw you coming out of a gas station with the tractor on a trailer on Hickman Road by I35 today. I was on to Waukee to see my daughter! It looked good on the trailer.
Pastor Mike
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2016 at 6:56am
That'll work great for you! if you can fabricate, whip up a 3-point kit and a pair of forks, and you can use it to pick up and move things around very easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2016 at 7:03am
45 looks good!
I think you will have fun with that tractor.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2016 at 7:27am
Oh you did good.  Enjoy!Thumbs Up
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
what66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2016 at 12:25pm
Thank you for all your help  guys I put in  new plugs changed the oil.
It runs great but it does smoke from number 2 I will fix it later.
It seems to have plenty of power and everything works OK.
Hopefully It just needs a sleeve or some rings.
For now I'm just going to use it as is I don't have a lot to use it for anyway.
Edited by what66 - 01 Feb 2016 at 12:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2016 at 1:23pm
Or perhaps just a stuck ring, which isn't unusual if they've been sitting for a while... one valve open, condensation makes the bore a little gunky, and it gets rammed in around the ring. Work it hardand you may find that will unstick it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2016 at 5:14am
Nice looking tractor for that price!!
Yes, work it HARD and if it's a stuck ring, that should pop it loose.  If not, it's no big deal, you can use it that way.  Just have to keep an eye on the oil EVERY morning.
It's upgraded to an alternator already for you!  You'll love it!!  Know where to find the serial number?
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2016 at 5:30pm
Well I pulled it into the shop tomorrow I will find out why she's smoking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2016 at 1:58pm
Ok guys I found out the problem the valve guides on the intake valve's are badly worn.
It look's like some one replaced the exhaust seats.
I made a tool and pushed out the guides without any problems now I just have to find some new one's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2016 at 5:41pm
Well looks like I need to rebuild the engine after all.Ouch
Anyone Know where to get a good priced Engine kit ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2016 at 6:21am
Glad to see you took my advice and not dilly dally. LOL! Great lookin' Tractor man. You should have a lot of fun and enjoyment wit' dat! Congrat's! If you ever need any wiring or electrical for that ole' girl, give us a jingle...
Steve@B&B
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2016 at 9:24am
We are all always trying to save money when doing any work on these old tractors, but I would urge you to buy a good quality rebuild kit, with as many American parts as possible. There are several vendors that advertise (and sponsor) this site that have decent prices, good quality parts and a wealth of knowledge to guide you when you buy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2016 at 6:30pm
Thanks guys which Pistons should I use the flat top or the bowl?
My engine has the power crater pistons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2016 at 6:40pm
I, personally, would stick with the Power Crater pistons. The flat tops are ok if you're using it strictly for tractor pulling, but the original equipment stuff is better for everyday use.
7.25/1 compression ratio pistons are available in 4.125" bore at very reasonable cost. 8.25/1 pistons (high octane/LP) are available in 4" bore, but they are very costly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2016 at 3:59pm
Well guys I got bad news the engine need's a complete rebuild.Ouch
I took the bottom apart today the crank is messed up on #4 and the rod is screwed too.
I think the crank can be saved but I will need a rod.
I know a rebuild is the best thing I just have to figure out how to pay for it.
The kit I found is $695 is that a good price?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2016 at 7:59pm
Sorry to hear that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2016 at 4:05am
Rod and bearing, perhaps. How's the piston fitment, and the sleeve bores?
What is your ultimate intent for this tractor's use?
Reason I ask- I've built up engines from a variety of donors, using combinations that were used, but still very serviceable for basic use.
If you're not planning on making it a high-performance competetor, not dealing with incredible wear, catastrophic damage, or physical trauma, you may have a substantial lineup of parts that really don't need replacing. If the pistons and sleeves are fairly well fitting, and sleeves aren't severely tapered or out-of-round, a set of properly gapped modern rings, one rod, a set of bearings, an oil pump and some emery paper on the crank might set the bottom end up for another 60 years, and leave the budget available to give the cylinder head a rehab...
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2016 at 2:08pm
I just want it use it around the yard no pulling or heavy use.
I tried to fix my c like that but it didn't work out I had to do a complete rebuild.
The head is ok I got the new guides and am going to get new valves.
I'll pull the crank and see from there.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2016 at 4:36pm
If you need a rod I have a couple laying around, $10/each plus shipping.
Edited by grinder220 - 23 Feb 2016 at 4:36pm
