WD 45 with Quick-Change Front-End, PS, AC500
Matt WI WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt WI WD45 Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 with Quick-Change Front-End, PS, AC500
    Posted: 06 Oct 2023 at 6:16am
Nice tractor with power steering and convertible front end option allows for swapping out wide and narrow fronts end with both adjustable wide and 2-wheel narrow included in this sale. (Also takes single wheel FE but I don't have one.)
Excellent sheet metal all around; steering wheel rubber smooth and 100% intact; 12v conversion; turf tires; curved shifter; front end loader with large and small trip buckets; rear 540 PTO; snap coupler; drawbar.  No three point. No ag tires.
Barn kept until two years ago.  Sand blasted and cold galvanized rear rims when I put turf tires on a few years back (minimal corrosion).  Could use new front rubber.
Running when I last used her two years ago but I need to change out the gas before firing up (that's why bucket is supported by 4x4s) and it's going to be a week or so before I can get to that but wanted to get it listed.
Has the usual oil leaks and rusted battery box. Needs alternator work or new wiring to alternator--was not keeping battery charged.  I rarely used it so just kept battery trickle charged.  One of the rear tires has a small leak.
Would make a nice working tractor or base unit for restoration.
Located in Milwaukee, WI and posted FB Marketplace this morning.
$3200 or best reasonable offer.
Edited by Matt WI WD45 - 06 Oct 2023 at 7:02am
Nuubie, WD45 Quick-change front-end, ps, AC500 front loader
