WD 45 three way switch
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 three way switch
    Posted: 04 Jul 2016 at 10:34am
Just ordered online the 3 way start/light switch thru Steiner, Are they OK or did I waste my money?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 1:47pm
I, personally, would rather replace the cutout (on the generator) with a regulator to avoid overcharging the battery, then replace the three way switch with a regular push/pull switch for the lights.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 3:24pm
Me too. That's the way my B is. It still has the 3 position switch, but it only operates the lights now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 3:45pm
I've heard the repop switches leave very little room inside the original box and will short out if your not careful about installation.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 3:46pm
I have taken several of those switches apart, cleaned them with WD-40 or a similar product and then put them back together and they function perfectly.  If you have your old one, try that.  Not a lot to go wrong in them except accumulate dirt for 60 or 70 years.  Just check the resistor to make sure it's not burned out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 8:27pm
We offer an exchange program on the round Delco style switch. A lot of our customer's told us those aftermarket switches that everyone sells do not fit well at all in the instrument boxes and they short out causing issues. Drop by our website for pricing on our OEM rebuilt switches.
Steve@B&B
bb-customcircuits.com
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2016 at 5:27am
The newer style switches don't fit well in the electrical boxes on the smaller tractors like the B/C/CA/IB or the Styled WC, since those boxes are smaller than the WD/WD45. The newer switches will work in the boxes of the WD/WD45 though, but can be a pain. Steve has what a person needs and does a great job!  Rick
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2016 at 6:17am
Yep they are tough to fit (B). I put in a piece of rubber against the housing to stop any shorts.
Charlie
