WD 45 starting problem |
Stanley ![]() Bronze Level ![]() Joined: 16 Oct 2009 Location: PDC, WI Points: 193 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Feb 2019 at 9:29am |
Recently had trouble starting. (have 12 volt system) Replaced battery, new cables & ends. Actually had starter out and serviced. The tractor will start if I pull it.
I took the starter out yesterday again and tried turning the crankshaft gear with a long punch. It will turn, but with a lot of force. When I try to start the engine barely makes a groan, sounds like a very weak battery or bad connection somewhere. The voltage from battery to starter drops to about 6 when trying to start. I think my problem is that something is making the engine turn-over too hard. Any ideas/suggestions?
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
What does the starter switch look like? The contact on the starter can wear and erode. The switch contacts can erode also , making a poor connection. I file can fix these contacts up if they aren't too far gone and you can hold your mouth right and keep the angles good for best contact.
It's a push button starter switch that's connected to the long starter rod.
Contacts look okay. I replaced the starter switch couple yrs. ago. I am pretty certain the contacts are clean and secure.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24704 |
If you 'jumper' the starter switch and it starts nice...it's the 'starter swich', if it doesn't then I'd say battery cables and or connections. I use premade cables NOT ones where I have to bolt/clamp/crimp/? the ends onto 'raw' cable. You NEED really good connections. How's the battery ground ? clean and shiny with new ,clean bolt and lock washer ?? A 12V battery dropping to 6 means there's a high resistance 'somewhere' in the wiring. 'high' in this case means a FRACTION of an ohm, which you wil NOT see on any normal meter. Jay
Thanks,Jaybmiller. I give it another "look see" tomorrow. Can't get to the farm today - rain, sleet & snow. Tomorrow just below zero temps.
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Pull spark plugs and use hand crank to rotate engine. If it turns easy then you have eliminated too tight an engine. Starter could be bad and pulling too many amps loading down new battery. New battery could be bad. Did you charge the new battery before use? These are just my thoughts.
1957 WD45 dad's first AC
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Agree with Stan. Could be bent/stuck push rods, valves or even stuck crankshaft bearings. You've gotta take baby steps and try one thing at a time.
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 802 |
he sad it will run if he tows it then engine is ok take switch off starter jump right on starter post with good battery ground jumper cable to starter
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12002 |
If you're running a 12V system, then you should have the Starter changed over to 12V using a starter relay either mounted on the Starter motor or on the Tractor. First, charge the Battery up, then do a draw test on the Battery to make sure your power supply is reliable. If the Battery passes, I would move to the Starter and have a reliable rebuilder run through it and set it up for 12V w/a relay. Move to a key crank start Ignition switch. Those old mechanical switches are the worst for transferring power, especially running the fast moving current of 12V's through them! With that type of king size voltage drop, my bet is on the Starter providing the engine is loose and nothing internal is going on with rod n' main bearings... We offer 6-12V Starter conversions done the correct way if interested.... Steve@B&B
A little more history - I've had the tractor for about 5 yrs. It had the 12 volt sys. when I got it and it always started easily. A few weeks ago the problem started. Thought battery as it was 5+ yrs old. I did charge the new battery and it held a charge, also had the starter out and serviced by a good rebuilder. He said the starter was ok. I have tried going from the battery directly to the starter post and still get a "groan", will not turn over the engine.
Unfortunately this tractor does not have the "pin" in the front for a crank. So, I'm not able to crank it. If I took out the plugs and tried to start, would that tell me if the engine is ok?
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54163 |
Yes, It takes compression issues out of the loop. How do the cables look? If they are corroded, or too thin, they can heat up, and cause resistance. Good luck...
allisbred ![]() Orange Level Access ![]() Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
May want to check the new battery for dead cells, I have bought batteries that had a short. My 45 is very tight with the hand crank, don’t think I have enough “** to whip it. Go back to a screw driver to jump starter and minimize all power losses then replace cables and switch. That will be much cheaper than digging in the engine.
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3927 |
How is your ground connection from the battery cable to the engine? Is the connection clean and shiny? Poor ground is a common problem.
Had a new tractor that didn't turn over good. Found cables were corroded on inside. This one could have got sea water in it on boat ride over here. MACK
wide ![]() Silver Level ![]() Joined: 29 Dec 2018 Location: north iowa Points: 169 |
Should turn over hand if you grab the fan belt and fan right?
I suppose if the clutch was dragging it would allow you to pull start but be hard to start with the starter,.. but wouldn't the tractor jump forward? |
truckerfarmer ![]() Orange Level Access ![]() ![]() Joined: 26 Jan 2013 Location: Watertown, SD Points: 3284 |
If transmission is out if gear probably would not notice tractor jump forward when it starts. Are you pushing the foot clutch when you try starting it? Just disengaging the hand clutch still leaves the PTO and hydraulic pump engaged.
You have replaced most of the components in the starting system, so that eliminates that. Like others have said check the ground cable, but also check that the starter is grounding to the bellhousing. Using a battery charger with boost mode, try connecting directly to the lug on the starter to eliminate if the battery, switch or cables are bad. Make sure it is out of gear if you try that. |
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
What problem? The starter not turning the engine over? Taking the plugs out will allow the engine to (should) turn over very easily, no compression. It won't really tell if the engine is ok though. Too many variables there. It will tell you that it is not locked up is all. Lets go back to when it all started, tell us what it did, what happened... |
Solved the problem. It was the starter. Had it checked once and was told it was ok, but after exhausting other suggestions offered by forum members, I went back to the starter. Thanks to all for the help.
