WD 45 SLOOOWWW Starter
JCSinPITTS,PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 SLOOOWWW Starter
    Posted: 23 Feb 2018 at 11:37am
Dad had the starter rebuilt and I took it back to get it checked, I installed new welding cable size cables with ends made at local wiring shop. I have cleaned the flat cable where it connects to housing and the starters been out and in so many times it has to be clean!  Has anyone ran an additional ground wire/cable directly to the starter bolt???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2018 at 11:52am
If it is still 6 volts, yes I have seen that done in an effort to improve cranking speed.  12 volts shouldn't need it.  WD-45 gas starters should have a center armature bearing inside of them to prevent armature flexing. Throughout the last 60 or more years, many reman starters may have been installed and maybe it has a WD starter instead of a WD-45 ??  Also, if it has more than 125 psi cranking compression, it isn't a standard engine anymore and maybe 6 volts ain't enough ??
polarbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote polarbear Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2018 at 12:16pm
DR Allis love your comments it is obvious you know your AC's
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2018 at 1:13pm
Doc shouldn't the WD have a four brush starter? Danged if I can remember.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2018 at 1:53pm
Can you have someone stick a voltmeter across the starter power stud and ground while you crank it? If the voltage drops below 5 volts on a 6 volt system or 10 volts on a 12 volt system the problem may be your battery or terminal connections.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2018 at 3:49pm
As Doug mentioned, the thing that's almost always overlooked is the Battery. Put a slow charge into the Battery overnight. Let it set for about 10-15 minutes after the charging process is done, then do a draw test. If the needle moves just a little then stays rock solid, the Battery is good. If the needle starts to drop, and keeps dropping slowly (or quickly depending on the condition) you need to renew the Battery. If the Starter has been converted to 12V's, in order to get direct power,  use a Starter Relay setup and eliminate the old mechanical switch. You'll eliminate most of the voltage drop, and send more amperage to the Starter motor to spin the engine.  HTH
Steve@B&B
