Wd 45 shifter
D14JIM14 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Topic: Wd 45 shifter
    Posted: 08 Feb 2021 at 9:49am
I took the gear shift tower off this 45 which as I posted before has set 30 + years and won't shift. Gears and forks and end of stick all look real good !
But I can't slide the forks and shafts they are on .
I guess I'll tear it down and clean and lube the detents and shafts etc .
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 12:28pm
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 2:08pm
Thanks Mike !
I'm using PB Blaster and getting the shafts to move with a rubber hammer .
I hope time PB and patience will keep me from a tear down .
Gears , shifter , and forks look real good !
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 3:49pm
Jim,
The shift lever has a lot of leverage on moving these forks. Is that how you have it set up out of the tractor? So you can use the shift lever to move the forks?
I assume the actual gears will move on the shafts in the transmission?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 8:43pm
only one rail will move at a time. With all rails in nutual, move one , then back to nutual, then move another.            MACK
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote D14JIM14 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 9:07pm
Thanks Mack
