WD 45 Shifter woes |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4177 |
Topic: WD 45 Shifter woesPosted: 7 hours 40 minutes ago at 4:52am |
Guys, need a little help. Pulled the shifter off the NFE 45 to change the gasket, it was leaking some out of the right front corner. Shifter has always worked fine. Tore it apart, yeah that gasket was done for, easy to see why it was leaking. Anyway, going back together the lower end of the stick got out of the forks. I can get it back where it belongs but it won't stay there. Not sure if some of the springs are tired or what. Really didn't want to tear this thing all the way down but may have to? Pretty sure if I can get it back together it will outlast me.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8609 |
Posted: 1 hour 17 minutes ago at 11:15am |
Mike,
Maybe shift forks have moved? A good light and a long stiff screw driver you may need to get the forks back into the neutral position? Now that I think about it I think the forks need to be in the second gear position to get he shift lever to be properly aligned as you insert the shifter?? I could be wrong and someone will be a long soon to help. I did a little work on the innards of the WD45 we did some repairs on. The info is on here somewhere. Regards, Chris and Cheryl
