Wd 45 shifter handle
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Topic: Wd 45 shifter handle
    Posted: 06 Feb 2020 at 6:56pm
Who makes the best quality shifter handles? I see a lot out there available and I wanted to get some opinions. This one has been repaired several times, guess it should be replaced.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2020 at 6:21am
I would guess that every aftermarket company that sells them is selling the exact same one from the same machine shop.
AaronSEIA
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2020 at 9:19am
I got one from an after market company, it did not have the knob on the end of it to hold the rubber knob on. If I were to buy another it would come from Sandy Lake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2020 at 10:47am
30 or more years ago, a new gearshift from AGCO for a WD/WD45 required a new large plastic knob like later 185's and 200's. The shift lever itself was probably 5/8" diameter all the way from the shift boot to the new plastic knob, not tapered like the original. It was obvious they had a new vendor and they made them for all orange tractors at that time in history.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2020 at 1:03pm
The one DJS shows in their catalog has a taper at the end and the ball for the rubber knob.
AaronSEIA
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2020 at 2:09pm
I have one on my WD like DrAllis descibed. Bought it in the early 1990's from AGCO. I just welded the correct bolt on the end so the old knob would screw on. I ground the weld down so you can't tell and only a watchful eye will see the thicker diameter shifter.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2020 at 2:10pm
I have a new one for a WD45 somewhere that I bought when I bought my WD one.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 4:11am
Lonn, If you want to let it go, let me know. Think I’ll call Sandy Lake and see if what they have are shaped the same, I am more concerned of the key ways and machining quality on the lower end. Most after market stuff in the past I have been disappointed with. Thanks for your suggestions! Kevin
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 11:59am
Look to see what Steiner Tractor Parts out of Michigan has.
