WD 45 piston rings?
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 piston rings?
    Posted: 14 Jun 2016 at 3:59pm
Went to the local dealership today to order a new set of piston rings for the WD 45.. seems the oil rings on the kit they gave me are a quarter inch thick and the grooves in my Pistons are only three sixteenths. the other rings grooves measure 3/32 on the top, and 1/8 for the two middle rings. a little different as well from A&I, Howard's, and Tisco.. does this make sense to anyone here and if it does what do I have for Pistons and where do I get a ring kit for them.. mind you these Pistons come out of my 45, I am just doing an overhaul due to the motor throwing a rod and I had to get a new block and different sleeves...
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 5:13pm
Call me 717-451-6590 7 am to 8 pm eastern time ,I can fix you up with the rings .
Do u have a 4 1/8 bore
Edited by Fred in Pa - 15 Jun 2016 at 11:53am
nonetheless ,still dead.
This page was generated in 0.081 seconds.
