WD 45 motor surging at idle down
Iowa_Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Iowa_Allis Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 motor surging at idle down
    Posted: 22 Mar 2012 at 6:38pm
My 45 surges/pulses after a quick idle-down. Otherwise it runs great. What causes this? Timing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Iowa_Allis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 11:02am
Bump.
Anyone?
If I have it at full or 1/2 throttle and back it off to 1/4 throttle or so very quickly it will not idle smooth and surges.
Ken McGregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken McGregor Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 4:51pm
Sounds like either a problem with the governors or perhaps if you are lucky, the spring attached from the block drain cock to the throttle rod is missing/broken/not strong enough to stop the surging.
Just a couple of thoughts for what it's worth. It's probably worth what it cost you anyway;>)))
regards,
Ken McGregor
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 6:31pm
  I would check to see if the throttle shaft seal is worn.  Spray some carb cleaner where the throttle shaft goes into the carb, and see if the problem goes away.  If it does, plan on rebuilding the carb, be sure to get a kit with a new throttle shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Iowa_Allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 8:05am
Thanks guys.  I'll check these out.
