wd 45 & m IH
Freddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freddie Quote  Post ReplyReply Direct Link To This Post Topic: wd 45 & m IH
    Posted: 13 Oct 2011 at 7:17am
How do they compare in horsepower and pulling ability? Assuming they are weighted right  and in good shape.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 7:46am
A Super M/Mta is more in the range for hp.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 7:49am
Most M's have the domed high compression pistons and many have the after market governor giving hp pushing 60. These piston kits have been sold by IH for decades. Compare that to Allis who stuck to original equipment sleeves and pistons from Allis for the WD45 until about 10 or 15 years ago. True many 45s have after market sleeves and pistons but in my experience most don't or didn't. Stock to stock IMO the 45 will out horse not only an M but will out perform a Super M but I haven't run into a stock M ever. Heck, even the mechanics at the CaseIH dealer I worked at 10 years ago didn't know an M came standard with 3 7/8" diam pistons originally. Considering all that a 45 will have a workout against 60 hp Ms but still a 45 can do it sometimes. 45s are uncanny at their power.
Edited by Lonn - 13 Oct 2011 at 7:49am
Wink
I am a Russian Bot
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 7:56am
I can agree with Lonn but the 45 will do the same work as a M on almost half the fuel. I wonder how the two would compare in there diesel versions.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 8:28am
A WD45 has alot of power for its size. Plus the snap coupler and traction booster, which let it pull a 3.14 plow with ease. On the other hand a Farmall Super M was rated at 3.16 "I think" and pulled them nicely. They both are great tractors but depends on what you want to use them for.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 9:10am
45s will pull 4x14 out of the box in many soils. Dad used to pull a 3x16 Oliver pull-type in 3rd gear in black soil. No snap coupler used with the pull-type. Just wheel weights and fluid. Stock for stock a 45 will do everything a SM will do and probably do it better when snap coupler and traction booster is used. My Dad grew up on IH and Case and when he moved to AC he said there was no comparison on the difference when he got his 45. He called it a tiger and sometimes a bucking bronco. Seat might have contributed to that last one but he always said you couldn't stop that tractor. It's the tractor that switch his brand to Allis back in the late 60's.
Wink
I am a Russian Bot
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 9:13am
I know what your saying, the 2 tractors are almost the same HP my MTA made 47.5 on the PTO dyno. That's what its rated factory.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 9:28am
BTW I'm not saying that the Ms were bad. Obviously they were real good tractors.
Wink
I am a Russian Bot
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 9:31am
If you want to buy one, buy the 45. Orange is always better!
This page was generated in 2.039 seconds.
