WD 45 LP Unconversion
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2016 at 9:08am
To hold my Woods mower behind my WD up to keep from scalping, I cut two pieces of pipe for around the lift cylinders that keep the mower from going too low.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 10:54am
Yesterday, (12/23) I started tearing down the engine that came out of the propane tractor. It always amazes me what you find when you tear into something this old. The oil-pump and pick-up surprised me the most. The pump has a 10 tooth tear on it, from a D-17 maybe?
Here is one of the reasons I removed the engine. You can see where someone trimmed the gasket when they put the pan on, it leaked like a sieve.
Another disturbing find, not sure what causes this. I did find the shims pinched between the halves of the bearing shells, that couldn't have helped. You can see in the picture just on the left side of the bolt hole where the shims were pinched.
The engine has flat top pistons, 4&1/8" bore. It is NOT clean like I have heard propane engines tend to be on tear-down. Who knows if it was built for propane or ran on gas for quite a while? Had 190 psi compression in the best cylinder. One sleeve looks like the wrist pin may have been hitting. The low cylinder had 175 psi when I did the compression test. Maybe I should start a separate thread for the engine portion of this?
Edited by IBWD MIke - 24 Dec 2016 at 10:59am
This page was generated in 0.049 seconds.
