WD 45 Loader
BH Reinen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BH Reinen Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Loader
    Posted: 29 Jun 2010 at 9:38pm
What do I need to repack the rams on my WD 45 front end loader? Thanks Bart
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2010 at 9:51pm
Maybe Danny will see this and get on here and give you the low down on repacking them.
Don
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 5:47am
Bart,
******Check with your dealer to make sure this information is correct.*********
All you will need is 8 of part # 72000650 (packing) they cost me from a local ac dealer 27.51 shipped to my house. Here's the link on rebuilding them, select slide show in my link when you get to photo bucket if you have any questions pm me.
Danny
Here is the pictures of rebuilding of the loader cylinder for a WD9 today!
http://s577.photobucket.com/albums/ss212/dannyraddatz/?newest=1
Edited by dannyraddatz - 01 Jul 2010 at 7:41am
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 6:09am
If the cylinder looks like this picture, you can tighten the packings by closing up the gap shown. Do not over tighten. Some oil must weep through to lubricate the packings. If the rods are pitted or have deep scratches they will eat up seals no matter what you do. The options then are, get new rods made, live with the leak, or buy different cylinders. (credit picture to Danny)
tbardell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbardell Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 11:21am
Good thread so far.
I just re-packed mine last week- and it worked very well, the old rams seem to be fine holding 100% now with the new packing. I was worried about the rams being out of round or pitted, but they seem to be good.
One Question:
How tight should I pull the end caps down? I am afraid I may have them too tight now, possible starving the outer-most packings of oil.
Thanks! Trale
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2010 at 8:20am
Did you bleed the piston bearing at the bleeder screw, remember it should be done each day before you lift. The problem is if you have air in the cylinder and try to lift the air will escape, this will cause heat friction between the ram piston and seals and cause a friction burn. Then over time the the seal develops a leak, in the picture Tucker posted you will see the bleeder screw. Make sure you know what your doing when you bleed the cylinder, Hydraulic fluid is very harmful to the human body, wear PPE. Back to your question that is a paint stirrer I used as my gauge for the first tightening down the cap. You should see a fine film on the piston but not a leaking from the top of the cap.
Danny
Here are 2 pages from the owners manual for the loader, you should try to get one, this should answer your question.
Edited by dannyraddatz - 01 Jul 2010 at 9:19am
Danny Raddatz
This page was generated in 0.107 seconds.
