WD 45 lift cyl snap ring
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 lift cyl snap ring
    Posted: 25 Oct 2016 at 9:51pm
Guys, how do you get this darn thing back on the end of the cyl shaft? We did not take it off, found it in the cylinder when we took it apart. There is no way to get snap ring pliers on it. Thanks Much. Tom
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 10:12pm
Spread it with one pair of snapring pliers enough to get another into ends.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 8:02am
Thanks MACK tried that but there is no way to get a pair of snap ring pliers on the ends of the ring. Cut sorta like this on the ends with no hole to put pliers into ~.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 8:39am
If that is the round wire type of ring, you might be able to sharpen it a bit to use flat tanged pliers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 9:11pm
Found a pair of retaining ring pliers used to rebuild auto tranny's, should have it on right after work tomorrow.
