WD 45 Hydraulic pump question.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Hydraulic pump question.
    Posted: 5 hours 18 minutes ago at 5:45am
This may get long but stay with me, please.
I have a model 73 semi-mount plow. Been here a few years, hadn't used it, decided to take it to the swap meet Friday. Didn't sell. I've gotten all the adjustments free and the tire holds air. Talking with Dave the Plow Man at Lathrop he cleared some things up for me. The 60 series (looking) coulters were available on the early 70 series plows. The bottoms are 375 non-shin units. Shares are unique to that bottom and not great. But, I think I have new ones. If so, they are going on. Might just as well, don't fit any of my other plows. So I'm getting more interested in this silly thing.
Another option would be to convert it to slat bottoms. Have several around here loose and a parts plow. I rather like this angle.
Having said all that; If you set the hydraulic pump to 'delayed-lift', for the tail wheel, will the traction booster still function?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 13 minutes ago at 5:50am
Well, how about a 2 for 1?
My WFE 45 is getting a bit low on pressure, thinking 3100 psi or so when last I checked. Searching here and looking in my books I didn't find any information. Pretty sure we have discussed 'shimming' to adjust the pressure.
Any insight would be much appreciated.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 16 minutes ago at 6:47am
I don't have a tail wheel or gauge wheel on my 73 plow. I use the traction booster and it works great. Look at my website to see the video of me plowing with it.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 52 minutes ago at 8:11am
I think it might, but you'd have to do some different plumbing. The left lift arm cylinder would  have to be connected directly to the right lift arm cylinder, so they would work together. The hose that formerly went to the right lift arm cylinder would have to plug into the hyd tailwheel on the plow.  Plumbed this way, the lift arms would come up first, then the tailwheel. Lowering, the arms would drop before the tailwheel. The Traction Booster screw "A" would have to be unscrewed. If you know the TBoost system works now, it would be worth a shot. What you are doing is what the Transport valve was for.  Good luck, Mike !!
