wd 45 hand clutch grabs
Deac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deac Quote  Post ReplyReply Direct Link To This Post Topic: wd 45 hand clutch grabs
    Posted: 02 Mar 2020 at 8:01pm
Hello All, I have a 1956 WD 45 with a hand clutch that grabs hard when engaged even very carefully. No slippage when engaged, oil level is full,foot clutch is fine. It makes it hard to ease into anything.....Any thoughts on this??
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 8:07pm
when mine lost it's lining....it got grabby
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 7:01am
If it was mine I would take the cover off and look inside.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 10:02am
Mine grab too! Thats another reason I dont like hand clutches! -- IF I wanted hand clutch I would use the green tractors! --- They sit for that same reason,---HAND CLUTCHES!
Linings in wd's could be gone, also the plates might be warped.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 10:52am
The Allis hand clutch is very durable and robust. They are just getting worn out and need some TLC. Once they have been rebuilt they will last for decades.
Take the hand clutch in the "CA" that most people complain about. It's the weakest clutch of them all. I rebuilt it in 1998 and I just had to rebuild it in 2019, that's 21 years. That was my main tractor (only tractor) until 2014. I worked that tractor hard. It did all the plowing, planting, cultivating, disking, cutting hay, baling, raking, harvesting and snow removal.
Once the clutch is rebuilt correctly it will not grab but be nice and smooth.
Thanks & God Bless
Dennis
Deac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deac Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2020 at 8:21pm
I will open it up and have a look.  Thank you all for your replies, Deac
This page was generated in 0.346 seconds.
