WD 45 D Grader Blade Cylinder
DJKinTexas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJKinTexas Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 D Grader Blade Cylinder
    Posted: 29 Jul 2024 at 11:34am
I have a WD 45 D Grader with a bent shaft on the hydraulic cylinder that moves the blade left & right. The time to get it repaired is longer than I want to wait. I thought I'd reach out and see if anyone might have one.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2024 at 11:08am
Seems replacing a shaft on a cylinder at a hyd shop would be a 1 day event at the most .
Had new shaft and piston made up for backhoe at shop here - took 2 days as had to machine the shaft to accept the new piston they made .
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2024 at 11:12am
Another way is to check Surplus Center and see if they have any cylinders that would work for you .
 They should have their listing online of what they have in stock
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJKinTexas Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2024 at 12:05pm
Thanks
