wd 45 crank installed in wd block
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 4:44pm
heres what happens when you mill to thin.
I know you guys were waiting anticipating
gold642 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gold642 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 5:29pm
Call me a chicken I think I'll take my chances with 9.3 compression and leave the pistons alone. I will run high test and adjust the timing accordingly. Thanks to everyone for their input. I don't think I explained that I am doing two tractors. They are both wd45's but one had a wd engine in it. One has wide front and power steering (1955). I ordered the 8.2 compression pistons for the wide front wd 45 engine. I am locating  9 spring pressure clutches for each tractor. I had the radiators recored and the gas tanks lined . I sent the heads to the shop for valves guilds and seats. I have a spare wc and wd  for parts. I still need to find snap couplers for the lift arms. The tires and rims on the wide front wd 45 are in great condition and calcuim filled. The tricycle (1954) has bad rims that I intend to replace and then fill them. The tires are excellent shape. I have 6 Allis plows . 3 -2 bottoms mounted , 2 - 3bottom mounted, and a 3 bottom drag plow. I have been pulling plows out of the snow every where on our farms. As Dr Aliis might remember I am going to try to out plow a Moline Ub special pulling a 2 bottom drag plow.  The narrow front with the wd engine  will pull a two bottom. The wide front will pull a 3 bottom. I will raise the left side of the tractor 6 inch and adjust the plow flat to the concrete floor. I intend to hang 2 weights on the left rear wheel of the wide front tractor.I would do both tractors but I only have two wheel weights. I will bolt a chain both to each front end. I figure about a 100 lb of chain up front should work well. I have a lot of chain, Don't ask.  I will wire brush the boards and plow ahead of time to insure everything is operating and shined up as it should. If I can figure out how to load pictures I will try to post some. Thanks Ted
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 5:35pm
My brother uses 4.125 WD pistons in his  4.5 45 crank  and has never had any problems ,although he uses 89 or more gasoline.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gold642 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 5:35pm
Sorry It should say chain box not both. I am using a steel box to hold the chain. The wd and wc are shares but ran a couple years ago when parked. I was going to sell one and cannibalize the other for parts. Which would be worth more? Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 6:02pm
I knew a little visual aid would bring you around . Even if I am Rodney Dangerfield and cant get any respect from just simply writing posts.lol
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 6:12pm
nuttin a little JB Weld can't fix!
I am still confident of this;
Wait for the Lord;
This page was generated in 0.262 seconds.
